split the characters based on the length
How I can split string such as "HELLO"  => "H"  "E"  "L"  "L" "O" by using the length
Message 1 of 14
(5,576 Views)
Is the right side an array of strings?
String subset in a for loop with i wired to the position and 1 wired to lenght would do. Autoindex at the output tunnel.
Set N to the string length.
Message 2 of 14
(5,575 Views)
Accepted by topic author OATTelecom
Yeah Type cast!Smiley LOL
Message 3 of 14
(5,567 Views)
That was my initial idea, but I was on the bus and decided it was too hard to describe in words to a newcomer. 😄
Message 4 of 14
(5,564 Views)
<tounge-in-cheek mode = True>
I believe that having a Graphical representation of code offers many benefits over text descriptions of code.  Wouldn't you agree?  😄
Don't they allow laptops on busses?
Message 5 of 14
(5,557 Views)
The mouse is harder to control due to the rattling and I would need to turn my phone into a WIFI access point to have internet (via LTE) on the laptop. Too many steps. 😄
Message 6 of 14
(5,551 Views)
Sorry, in addition if I want output in form of binary , what should I do ?
ex . H = "01001000"
thank you
Message 7 of 14
(5,527 Views)
Use "string to byte array" and set the display format of the U8 array to binary, 8 digits, pad with zeroes.
(If you want something else, you need to tell us the desired output datatype. E.g. you could format each number into a string containing the characters 0 and 1. (%08b))
Message 8 of 14
(5,517 Views)
how to set the display format of the U8 array to binary, 8 digits, pad with zeroes.
Message 9 of 14
(5,499 Views)
Display Format for the properties page of the numeric indicator that makes up the array.
Message 10 of 14
(5,490 Views)
