splitter Position property doesn't make sense
The "Position" property's outputs for these splitters (in the attached code) don't make sense. The splitters are not where the property says they are.
It looks like Property tracks the upper-left corner of TotalBounds. Is that right? How do I find out where the top of a horizontal splitter is on the Panel?
(2,525 Views)
Accepted by topic author David_Staab
David, I believe you want "Splitter Position" not "Position"... See attached.
Charles Chickering
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(2,522 Views)
Good grief. I swear, some days you stare at the code so long it disappears.
Thanks for the help, Charles!
(2,512 Views)
