splitter in tab control
is it possible to add something like splitter in tab control ?
Sincerely.
SLt
(6,899 Views)
You have a couple of options:
  1. Use a decoration and move and resize it yourself.
  2. Use a subpanel on the tab and create a splitter on the subVI hosted in the subpanel.
If you need help with either of these, please ask.  Both require use of VI server.
(6,868 Views)
Hello ,
Please give some more details of , how to create a sub panel in the TAB?
or any example would be of grt help.
(6,648 Views)
Just place a SubPanel in the tab (found under container), and connect a vi ref to the Insert Panel property.
Check out Find examples -> Subpanel.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,643 Views)
