splitting array index further
I want to split the array(0) index into further indices.
Means in my applciation i'm getting array(0)= 4897 (for ex)
But i want the output array as array(0)= 4
                                                array(1)=8
                                                array(2)=9
                                                array(3)=7
(3,156 Views)
Hi
Do you get an array where the element at index 0 is 4897 (which means a single number)? Or do you have a "horizontal" array?
Maybe you could post your code or a screen shot.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,149 Views)
You can do it using Quotient & Remainder function. I have made the assumption that the number is an integer and not floating point. Its not a good idea to check for equality between floating point numbers
David
Edit: spelling
Message Edited by David Crawford on 12-05-2006 01:11 PM
Message Edited by David Crawford on 12-05-2006 01:13 PM
(3,150 Views)
