splitting arrays
LSASS wrote:
I am usind the Array subset to split my huge 1D array in to chunks of 8. But I am unsure as to what to pass in to the index input of the Array subset function. When I put it in a for loop, the index continuously changes. So what do I input?
Split it into what? Please show us your code so we have a better idea.
The index is zero at the first interation and increases by one for each later iteration. Multiply it by 8 and wire to the index input and set the size to 8 and you get the next eight elements per iteration.
As has been mentioned before, "reshape array" is probably the better tool.
Message Edited by altenbach on 05-10-2009 03:43 PM
Message 11 of 23
(1,986 Views)
LSASS wrote:
Hello smercurio,
You input the next multiple of 8, based on the current iteration value. When iteration = 0, the value you input is 0. When iteration = 1, you input 8. When iteration = 2, you input 16. When ...
The Reshape Array method would not require this since the for-loop can be auto-indexed from the resultant 2D array.
Message Edited by smercurio_fc on 05-10-2009 09:05 PM
Message 12 of 23
(1,970 Views)
Hi
   I think use  property node,i am not conform , try it.........
Regards
Munna
Message 13 of 23
(1,953 Views)
hello lsass,
i don't know if your sequence can be present more than  one time or if your data are double or not or are
exactly the same.
Here is a suggestion
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 14 of 23
(1,938 Views)
LSASS wrote:
[...]I have a problem: I have a huge 1D array and I need to split it in to sets of 8 elements as need to compare these 8 elements with another  1 D array of size 8. [...]
Well, coming a little late into this discussion...but reading this sentence sounds like a pattern match to me. Maybe this is better in regard to performance than to split the array and do the comparison afterwords.....
just my 5 cents,
Norbert
Norbert
Expert: Geometry
Message 15 of 23
(1,931 Views)
Smercurio
Great Idea for decimation
LSASS is what you are looking for?
- James
Using LV 2012 on Windows 7 64 bit
Message 16 of 23
(1,915 Views)
James, you can eliminate the "AND array elements" by setting the comparison mode to "compare aggregates".
Message 17 of 23
(1,911 Views)
Thanks !  that is a cool feature
- James
Message 18 of 23
(1,908 Views)
hello,
you could also swap  0 and 1 reshape entries and replace number to decimate command with
size of sequence looked (3) , it will avoid to use a transpose array function.
regards
Tinnitus
Message 19 of 23
(1,886 Views)
Tinnitus  I have to dissagree with your method to eliminate the transpose array
In this example the number of "Channels"  = the number that you wish to decimate by which = 4
and there are 3 samples for each channel
applying your proposed changes does not yield the same dataset   (you can not simply change the number to decimate from 4 to 3) because the array size of the match pattern is how many samples not channels
the only way i can think of to eliminate the transpose array is to index the array manually instead of using the autoindex
- James
Message 20 of 23
(1,878 Views)
