spreadsheet
    I am using Labview 8.2. I am collecting data using "write to spreadsheet file(DBL).vi" . After collecting data, I need to delete these file.
But, Not able to delete these file. Why is that? How can I do that?
Please let me know..
Jey
Message 1 of 10
(4,849 Views)
You should be able to use Delete in the Advanced File Functions palette.  Write To Spreadsheet File doesn't return a file refnum, just a path, so I'd assume it does all the file open/write/close stuff for you.  How are you trying to delete the file? Do you get an error?
Message 2 of 10
(4,838 Views)
yeah I'm not clear what your problem is, I did a little mock up and everything seemed to work fine.
1. write (specify path)
2. read
3. delete
Message 3 of 10
(4,829 Views)
I found a discussion on deleting files.
http://forums.ni.com/ni/board/message?board.id=170&message.id=5813&query.id=12368#M5813
Hope this helps.
Jae Ho
Message 4 of 10
(4,824 Views)
Thank you Guys,
                          Now I able to delete these files.
One more thing, It is a huge file, It collects data for every seconds. The test run for 17 days.
In the middle of a test,The test program get frozen. Because of lack of memory.
So, Just want keep the last 2 hour data or 200 rows of data (for example).
How can I implement this? Is there is any function available to limit the data.
Because time to time we need to check the data. Only want to keep for the latest data.
Jey
Message 5 of 10
(4,815 Views)
Programming > File I/O > Advanced File Functions > Get Byte Size
You can check the size of the file with this function.  If it gets too big, delete it, else, just let it run.
Message 6 of 10
(4,806 Views)
Thanks for the support.
Jey
Message 7 of 10
(4,803 Views)
Smiley Indifferent    One question: When i create a Spreadsheet file on my VI i cant acces it directly from Exel because it says that it is being used by another program.....
The thing is that while the program is running i need to send this files over internet and i cant because of these...
¿How ca i close a spreadsheet file?
Message 8 of 10
(4,421 Views)
Hi isaac84,
Have you tried the close file vi from programming>>File I/O> Close File?
Give that a try, if not, please provide more information
Thank you
Van L
NI Applications Engineer
Message 9 of 10
(4,396 Views)
Hello Van
Yes the problem was solved with close file, Write to spreadsheet file VI has no opening or closing operation need, is just that i wanted to write headers to the file but only once when i created the file, so i try to create the same file every time i write to it, if an error ocurs then the file has been already created and no need of writing headers again, once opened the file i must close it afterwards.
Thanks for the advise
Message 10 of 10
(4,392 Views)
