sql database connection using active x in labview
I want to create a connection with SQL data base with the help of connection string by using active X automation in Labview. I do not want to use the pop-up (Dialogue of database) use to configure the connection (selecting database, server name, user name & password etc).
Thanks for any suggestion
(4,604 Views)
Create a text document on your desktop, rename it something with a .UDL extension, and then double click the file to setup the connection properties.  After configuring and testing the connection, click OK.  Now right click the file and open it with a text editor like Notepad or WordPad.  You will find a connection string that you can use in the DB Toolkit.
aputman
(4,602 Views)
Or you can just pass the UDL file path into the Open Connection of the Database Toolkit and it will do it all for you.
(4,599 Views)
Thanks Aputman for the reply,
Actually I have created the connection string after configuration the connection as u told in the post. But Now I want to stablish the connection everytime using the LabVIEW.
Thanks Crossrulz,
Actually I do not have Database tool kit on my PC. So I want to use Active X automation VI to perform the action. Can you help me in configuring the connection using Active X.
(4,593 Views)
Do a search for LabSQL.  There may be other toolkits but this is the one I used before I got the NI toolkit.
aputman
(4,589 Views)
