square pulse frequency dependant on time rather than sample rate and size
anyone know if it's possible to create a square pulse with its frequency dependant on time rather than sample rate and size?
for example if i set the frequency to 10. it means 10 pulses in ONE second.
rather than having to adjust the sample rate parameter and use the equation
frequency = [(# of cycles) * (sample rate)]/sample size
thanks in advance. would appreciate a picture of the block diagram if it's possible
Message Edited by sdkpark on 10-11-2009 04:39 PM
(2,732 Views)
Accepted by topic author sdkpark
nvm i got it solved 🙂
(2,716 Views)
Can you please post how you managed to solve your problem. This will help others in the future. Also use full words rather than short messages. (hope nvm means never mind).
Mathan
(2,697 Views)
