square root symbol in front panel
Hi Gerd,
Even in a cluster it loses property. Pls see the vi attached.
Message 21 of 26
(1,346 Views)
Hi R,
You r LV version is 12 and mine is 8.6.. couldnt open the vi. Could you pls see the vi that I ve posted as reply to Gerd? is that what you have done? Or else could you post a screenshot?
Thanks!
Message 22 of 26
(1,346 Views)
Hi pcs82
below i am attaching the code in LV 8.6
Message 23 of 26
(1,342 Views)
You never set any properties for the elements of the cluster, just for the plain string indicators. You just need a little bit more code.
Message 24 of 26
(1,340 Views)
Here's how to do it with the cluster (LV 8.6).
(You have several questionable code constructs. The sequence structure serves no purpose. Doing the array-to-cluster-unbundle dance is clumsy. All you need is a "index array" resized to the number of outputs you require. As already mentioned, you never operate on the properties of the cluster elements, so nothing will change there, of course. You have way too much duplicate code)
Message 25 of 26
(1,336 Views)
Hi all,
Thanks for all that help. Mr Altenbach is right, my code could be cleaned up a lot. Thanks for pointing out that. I ve been learning mostly by myself, and its been just a couple of months with LV.
My query has been answered. Thanks!
Message 26 of 26
(1,295 Views)
