sr530 driver labview 6
good morning.
can some1 help to post the driver for sr530 for labview 6. in NI driver  i could only get 4 labview 7 and 8.
thanks
regards
shamaran
(2,660 Views)
Hi Shamaran,
We typically support all instruments and drivers for two preceding versions so LabView 7.0 would be the minimum version that this driver would be available for. You can eithr upgrade to a higher version of LabView or wait to see if someone on the forum or in your knowledge has an older version of this driver.
Ipshita C.
(2,647 Views)
thank for the reply.would like to request any forum member having the labview driver for sr530 lock in amplifier plz post it for me.
help will be highly appreciated.
regards ,
shamaran
(2,634 Views)
I can't do the conversion but you could help your cause by attaching the file you want converted. It would make it easier for someone to help if they did not have to going searching for the file.
(2,628 Views)
