ssb generation vi?
I need to know which arb. waveform gens. will support am ssb generation vi, I own a PXI 5401, but it doesnt support this vi, can someone help?
(4,054 Views)
I'm sure there are others on here that know more and can help better, but does this help?
Edit: Oops, I attached the wrong link. Does this help?
Cheers
(4,050 Views)
This one might need a bit of NI support to explain it fully
The Modulation Toolkit contains "MT Modulate AM.vi" which has a SSB Polymorphic instance
The Examples even contain this vi
The example finder lists the following hardware:
(Darn it would be nice if I could resize that rather than just scroll)
The MTK Readme(4.4) current is 2015 but those DVDs haven't made it to me yet,  list support for the following hardware
So, we have a bit of a disconnect in the example finder and installed toolkit versions.  Honestly, I don't think you'll find support for the 5401.  Although, some old version of LabVIEW / MTK may have an equivallent vi with hardware support for the 5401, I almost never recommend downgrading software over upgrading hardware.  Frankly, this is one I would use my SSP on and call an NI AE and see if they can make sense of the problem and recommend a solution.  Your system, as is, is NOT going to get you there and be maintainable.
(3,998 Views)
