stack plot in XY graph
There are stack plots and overlay choice in waveform chart, but I didn't find such choice in XY graph. Because I use time axis in a real-time measurement, XY graph has to be used. How can I let the XY graph has several y axises in different scale just like the stack plots in chart? I use Labview 6i. Thanks!
(6,459 Views)
Unfortunately the XY graph just doesn't have an option to do stack plots like the waveform chart does. Additionally, the waveform graph cannot stack plots. You could use 3 different XY graphs to simulate the behavior of stack plots or you could draw multiple traces on one XY graph system (consult context help for a discription of this). I will attach an XY graph example that displays 3 XY plots formatted to look like a stack plot.
(6,459 Views)
Because the measurements have many channels, to put many xy graphs in the program seems unconvienent. To put all the traces in one graph and shift a little also need much work to do. I hope the new version of Labview will have the feature.
Because I use 6i, the given example in 6.1 can not be displayed in my PC. Any way, thank you, Blimpie boy!
(6,459 Views)
