stacked bar chart with custom x axis labels
Is there a way to build this simple chart in labview that I did in Excel?  I need to have many x axis labels and there could be from 5 to 100 of them depending on the data set.
Message 1 of 8
(6,692 Views)
Hi id,
Here is a link to an example VI that uses nested loops to turn a table into a bar graph.
https://decibel.ni.com/content/docs/DOC-2241
Hope this helps.
Anna L
Message 2 of 8
(6,644 Views)
Thanks the nested loop example helps a little but it does not create a "stacked" bar graph but rather a grouped bar graph.  I would probably have to sort and overlap the bars in order of magnitude for the thing to work.
The other issue is that the caetgory names on the x axis that I need to use are long and cannot fit horizontally so I need them to be vertical.  The 3D bar charts have this ability with their valuepair properties but I dont see away with the old 2D graphs....
Message 3 of 8
(6,635 Views)
Hi id,
Thank you for your response. I hope you are doing well.
There is an example in the LabVIEW Example Finder (Help>>Find Examples..). It is titled, Stacked Bar Graph. You can search for it if you switch tabs in the Example Finder window. This should help you create a stacked bar graph. To help you with your veritcal axis labels, here is a knowledge base link that details the process:
How Can I Customize the X-Axis Labels On My LabVIEW Graph/Chart So They Appear Vertically?
http://digital.ni.com/public.nsf/allkb/1F7C1B089E45908E86256C8C0051894A?OpenDocument
Let me know if these examples help.
Anna L
Message 4 of 8
(6,618 Views)
Thanks Anna but the means of putting labels vertically is kind of "cheesy" as it overlays controls over the x axis values.  This approach only works for a graph that you dont zoom or change the x axis range on for interactive viewing.   I tried doing it with a picture control overlapping and it gets pretty complex.  NI definitely needs to add this feature.
Message 5 of 8
(6,616 Views)
Hi id,
Thanks for your response. You can definitely post the vertical axis labels as an idea in the LabVIEW Idea Exchange. Here's the link if you are interested:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/idb-p/labviewideas
Best Regards,
Anna L
Message 6 of 8
(6,599 Views)
Anna, do you know of an Active X or .NET control that can be used instead to allow this feature?
Message 7 of 8
(6,595 Views)
Hello id,
I don't believe there is an Active X or .NET control that can be used for the feature. If you are interested in trying it in CVI, there is a way to manipulate your axis labels. There is more description of the process in this Knowledge Base article here:
How Can I Customize the X-Axis Labels on My CVI Graph So That They show Vertical Text Labels? http://digital.ni.com/public.nsf/allkb/C3637DA680F5407486256C8C0058B7DA?OpenDocument
Anna L
Message 8 of 8
(6,575 Views)
