stacked plots
how do you direct data to individual plot within stacked plots? (ie data set 1 and 2 to top stacked plot, data set 3 to bottom stacked plot.)
(3,755 Views)
Hi amazed,
For your application please take a look at the following KnoKnowledge Base article wledge Base article as well as the related articles that it has.
(3,573 Views)
What kind of plot are you trying to do here? When you stack plots, they are each separate sets of data, so you really can't have set 1 and 2 on the same plot in a stacked plot arrangement. Instead, you probably want two separate plot indicators, one of them in Overlay mode and the other in Stacked mode.
Cheers
(3,566 Views)
Trying to group command and responses of device . Data to and from have much different amplitudes  Thought that the stack plots would be the neatest cleanest gouping method.  No big deal - just thought it was something that might be easily done.
Thankyou
j
(3,558 Views)
