standalone applications in labview evaluation version
Can I make Standalone applications in labview 8.6 evaluation version??
Can this application work on other computers which do not have labview installed??
(2,706 Views)
You cannot because in the evaluation copy there is no application builder.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,704 Views)
Are you sure about that? Maybe it was different for the 8.6 eval version - I don't recall. I know the 2009 eval version does contain the app builder. You get a watermark on the front panel of VIs (including the built apps).
(2,682 Views)
