standard report error
i have a problem when trying to print document using standard ni report
i use the vi give in exemples to test and it crash also in runtime , not during developpement
it seems that it doesn't find report class where it is expected
the lib is present in my project but seems not to be added during building
here the error message :
"Get LV Class Default Value.vi<APPEND>
<b>Chaîne d'appel complète :</b>               //  full call chain  //
     NI_report.lvclass:New Report.vi
     print monitor graph.vi
     trait données clim.vi
<b>LabVIEW a tenté de charger la classe à ce chemin :</b>                //  labview tryed to load the class using this path //
D:\builds\projet clim monitor v4\Tmon.exe\1abvi3w\vi.lib\Utility\NIReport.llb\Standard Report\NI_Standard Report.lvclass"
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,305 Views)
does it work for you ?
Tinnitus
(3,283 Views)
Accepted by topic author tinnitus
in fact
it is needed to add report standard file to project then always include in builder option
(3,262 Views)
