standard report
I´m programming with the Standard Report Generation toolkit and LabVIEW 8.5.1.
The Append Image to Report ignores the Alignment in Standard Report mode.
Is there any way to align (center or right) an image in Standar Report mode.
simbani
(2,925 Views)
Hi simbani,
The alignment parameter is meant to be used with html, Word and Excel reports and is ignored for the Standard Report type.
If you need to use this report type, I would suggest to either align the entire document the same as the image or pad an image with white space so that it appears to be aligned correctly.
CesarV
César Verdejo
Training and Certification | National Instruments
(2,884 Views)
