stanford research systems DG645 Ethernet interface with LabView
We controling the SRS DG645 with Labview 2016 via Ethernet interface. We have upgraded LabView to version 2023Q3 64bit. Now we are unable to connect to the device, ni-max does not recognize the device.
We replaced the communication cable. We checked the settings of the DG645, and there is no change. I would appreciate your assistance.
Message 1 of 8
(1,368 Views)
Do you use VISA or the TCP/IP function to communicate?
Santhosh
Soliton Technologies
Message 2 of 8
(1,347 Views)
Can you upload screenshots of MAX and the LabVIEW VI? Do you get an error when you run the VI?
Message 3 of 8
(1,320 Views)
We use Visa.
Attached are NI-MAX, LabVIEW vi and screenshots of the error message.
In the network devices the DG645 appears in the list due to importing a previous MAX configuration file (didn't help to solve the problem).
Message 4 of 8
(1,297 Views)
Thanks for the screenshots.
1. What is the value of the "Choose Instrument" VISA resource control that is fed to "Initialize.vi"?
2. In the MAX screenshot the IP address of the "DG645Lan" is 169.254.60.22.
       - Is this the IP address you expect?
       - Is the computer on the same subnet as the DG645 device? The computer should have an IP address of the format 169.254.60.xxx, and a subnet mask of 255.255.255.0
3. If you can, try excluding LabVIEW 2023 Q3 64-bit from any form of firewall. You can use the Windows Defender Firewall settings in the Windows Control Panel. If you can, you can use that Control Panel to disable the Windows firewall completely to enable testing, but don't forget to re-enable it when testing is finished.
4. You are using driver VIs that are part of the "Stanford Research DG645.lvlib" driver. Can you find the webpage of that driver and check that it's compatible with LabVIEW 2023 Q3 and/or with LabVIEW 64-bit?
Message 5 of 8
(1,286 Views)
Accepted by topic author EYAL_FA
Hi santo_13 and Petru_Tarabuta,
Thank you very much for the help. The problem has been solved, here are the steps for dealing with the problem:
Make sure that subnet mask on the device and pc are the same and the IP address on the device is correct.
Then:
  • Go to NI-MAX  > Network devices  > add network device  VISA TCP/IP.
  • A "create new" window show. is the list choose auto-detect of LAN instruments > Press Next.
  • In my case no LAN instrument were found. > Press Next then entered the DG645 IP address, (LAN device name left empty)  > Next.
  • As Alias ​​written DG645 > Next > Finish.
The NI-MAX shows that DG645 is connected then I run the DG645 VI and it's worked.
I don't know what change because I have done these steps before.
Before these steps I went into the VISA settings through MAX and changed some of the settings, maybe that helped.
  • NI-MAX > Tools > NI-VISA > VISA Options.
  • General setting > remote > marked the check box of my PC name.
  • General setting > Passports > marked the check box of NiVisaTulip.dll--NI-VISA Passport for Tulip (32bit only) (Guess that didn't help to solve the problem)
  • Press Save.
Drivers installed:
  • NI-VISA 2023 Q3
  • NI-488.2 20223 Q3
  • Stanford research systems DG645 version 1.2 64bit (Installed via NI-Package Manager)
  • LabVIEW 2023 Q3
  • MI-MAX 2023 Q3
Again, thank you very much for the help.
Message 6 of 8
(1,203 Views)
Hi EYAL_FA,
To confirm, is your issue resolved now?
Earlier today, at 09:37 UK time (also UTC time), I received an automatic email from noreply@communitymail.ni.com that suggests that the issue has been fixed. The email seems to contain text that you wrote, but I can't see your reply in the forum discussion. I'm not sure what happened. Perhaps the web forum software experienced a bug.
That email is copied below:
Hello Petru_Tarabuta,
A reply to a topic you are following has been accepted as a solution!
Topic:
Author:
EYAL_FA (New Member)
Date:
14-11-2023 05:33 PM
Then:
  • Press Save.
Drivers installed:
  • NI-VISA 2023 Q3
  • NI-488.2 20223 Q3
  • LabVIEW 2023 Q3
  • MI-MAX 2023 Q3
Message 7 of 8
(1,223 Views)
Yes. the issue is resolved.
Thank you for the help.
Message 8 of 8
(1,134 Views)
