start and stop time
Good Morning
I like to set the time to start a program and time to pause the program and resume later at specified time.
Pls give me some guidance
Message 1 of 18
(4,052 Views)
Is the program that u are using going to be less complicated (eg: no stacked sequence and the whole program is inside a while loop?)?
Is it a big program and u would like to pause in the middle irrespective of which part of the code will be processed at that time (Pause time)?
Message 2 of 18
(4,049 Views)
Thankmuks
It is a simple program
I want the program to start running say from 8Am and pause at 5Pm and resume again next day at 8Am. I am thinking of doing the code in the while loop
Message 3 of 18
(4,047 Views)
I just created a simple program, seems working
Pls suggest me, what are the possible problems i will get if i use this method
Message 4 of 18
(4,044 Views)
Can you kindly post the code for lv 8.0?
Message 5 of 18
(4,035 Views)
I have saved in V8.0
Message 6 of 18
(4,032 Views)
looks good to me.
Message 7 of 18
(4,025 Views)
Thanks muks
Message 8 of 18
(4,023 Views)
It might look good (actually the colors are pretty bad, imho) but it does not work.
Why don't you use numerics for the start and stop times?
Message 9 of 18
(4,016 Views)
Thanks  Dennis
You mean, using the numeric and converting to string, If my guessing is wrong pls give some suggestions
Message 10 of 18
(4,009 Views)
