start automatically a top level VI in a library when logging into Windows
how do i automatically start a top level VI in a library in the Windows startup menu?
(2,739 Views)
hi,
two solutions:
1: create an executable out of your toplevel vi and create a link to it in your autostart folder.
2: create a batchfile calling labview with the full path to your vi (treat the llb as a folder "...yourllb.llb\yourvi.vi" )as a command line parameter.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,739 Views)
In 7.x option 2 only works if "Enable Windows Explorer for llb files" is unchecked under tools>>options.
(2,739 Views)
hi
i tested it under LV 7.0/Win XP SP2. the "Enable Windows Explorer for llb files" option has no effect on opening labview with a vi-path as a command line parameter, it works when option is enabled or disabled. remember to enable the vi-option execution->>"run when opened" when using option 2.
best regards
chris
Best regards
chris
(2,739 Views)
