state machine architecture and desired non-use of global variables
Hello everyone:
Consider a VI set up with state machine
architecture where, say 5 cases, include 5
different subvis. The cases are LIKELY to be
executed in order but I give the user a choice
using a menu of options (cluster of menu buttons).
Currently, I use global variables to transfer data
from one case to the next and things work fine, no
race conditions are set up. My question is
though, is there any way to avoid the use of
global variables and transfer data via wires from
case-to-case.
thanks,
don
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,257 Views)
.... maybe I just don't see this right, but why not shift registers?
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
(3,257 Views)
try using shift registers.
Regards
Pseudo
wrote in message
news:7qejla$4o1$1@nnrp1.deja.com...
>Hello everyone:
>case-to-case.
>thanks,
>don
(3,257 Views)
