state machine architecture for switching pneumatic solenoid valves using USB 6008
Thank you 😄
everything works now.
Elmira
Message 11 of 19
(1,195 Views)
you should recognize the posts w kudos that has helped you and or have given you a solution...otherwise, it was all done in vainSmiley Sad
Message 12 of 19
(1,188 Views)
apok ,
HOLD button and LEFT button don't work 😞 ??
Elmira
Message 13 of 19
(1,156 Views)
@Elmira wrote:
apok ,
did you take the suggestion that Sir RavensFan had mentioned? from what i see from your last vi post....
  • you have only 2 case statements for (0,1) or "hold" and ""right", both of which are (F,F) bool arrays?
i suggest you change the "hold" array to (T,T) and the "right" to (T,F) and add a third case (#2) the "left" to (F,T),....
  • so we 3 cases (0,1,2) matching cluster order of the buttons with respects to (hold, right,left) with bool arrays[ (T,T),(T,F) and (F,T)]
Message 14 of 19
(1,146 Views)
When I try to run each valve of the solenoid separately, it works and runs fine. However, when I try to run both valves on the parallel circuit (Darlington pair firing circuit), it appears to be working, as I can hear the "switching" sound, but it does not move the cylinder. What could be the source of this problem? I'm not sure if it is a problem in the circuit, or the program.
Thanks!
Elmira
Message 15 of 19
(1,122 Views)
Does the power source for the valves have a high enough current rating to power two valves at once?
-AK2DM
Message 16 of 19
(1,115 Views)
yes there is enough current raiting
Elmira
Message 17 of 19
(1,109 Views)
both ON means HOLD, correct?
Message 18 of 19
(1,105 Views)
That's correct
Elmira
Message 19 of 19
(1,093 Views)
