state machine pink icons
I just started to study Lab view, Í´m trying to build a State machine from  a self paced tutorial. My problem is that I don´t know how to get the icon in pink inside  the case state. I attached a file
(3,091 Views)
Accepted by topic author alexber2
I believe the pink icon is a local variable for a string indicator.  It is probably from an older version of labview because the icon is different now.  Right click the indicator, Create>>Local Variable.  Drag the icon over to the appropriate case on the block diagram.  Then right click the local variable, Create>>Constant for the constant string.  It's great you are being studious.  Good luck with your learning.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(3,078 Views)
Hi alexber2,
This pink icon is nothing but a 'Local Reference' of the 'Money Deposited' variable. As its a string control so the color is pink.
Just create a string control in any of the state in your diagram and then Right Click on it and make a 'local reference' on the bolack diagram.
Hope you got what you were looking for.
Thanks.
(3,065 Views)
I got the State Machine Now is done.Thanks a lot
Alejandro
(3,060 Views)
