state machine
It is still just a Value property.  You use the exact same data you would to set the value with a terminal.  In the case of an XY graph, it is likely a 2D array.
Message 21 of 27
(2,082 Views)
Thanks. But how can I implement that? Do I need to create two propety nodes, one for the X- and one for the Y-axis, with two separate references?
Christian
Message 22 of 27
(2,047 Views)
Use Value and wire in a 2D array.
John M.
Message 23 of 27
(2,018 Views)
How do you wire up an XY Graph terminal?  It is EXACTLY the same for the value property node.  It is just simply a 2D array.
Message 24 of 27
(2,012 Views)
Sorry everybody if I am hard-headed, but if I create a Value property node, LAB View won't allow me to wire it to a 2D array. That is why I am asking how to actually do this. I understand that I have to supply the X- and Y-axis. So, should I create a Value property node for each axis? And if I do so, how can I then merge the two references into a 2D array in the main VI?
Thanks in advance.
Message 25 of 27
(1,960 Views)
Accepted by topic author christianwos
Show us a simplified version of your code once more. (Your ealier code contains way too much garbage...:))
An xy graph does not accept 2D arrays. XY graphs accept a variety of datatypes (array of points, cluster of x and y arrays, complex arrays, etc.) and the terminal will adapt accordingly. If you want to write to a value property, you need to keep the same datatype used earlier of the terminal.
Message 26 of 27
(1,947 Views)
Thank you,
This was enough for me to figure it out. I unchecked "Include Data Type" from the refnum pop-up menu and now the XY-graph updates teh values normally. Thank you for your help.
Christian
Message 27 of 27
(1,942 Views)
