static/waveform digital voltage output and low frequency measurement - PXIe-6358
1.   I have a VI attached [digital_voltage_output] that should generate a static logical true or false state at the output of say device/port0/line1. When the VI is running I click on the button many times but nothing happens at port0/lines1.
2.   Similar thing happens [digital_voltage_waveform_output_square] if I try to generate a digital waveform at the same pin with the square waveform generating VI. If I connect a waveform chart to the output of the function generator VI, then the chart will show me the proper waveform I want but still nothing is written into the text file.
3. I've read the manual for X series cards but it is still unclear for me a bit how to route things in LV. I have a frequency measurement VI of low frequency measurement that I downloaded. It offers me the ports for frequency input - ctr0,1,2, etc. As far as I'm concerned the PFI ports are responsable for these kinds of actions. How can I tell the LV that I wanna connect say ctr0 and pfi0?`
I use LV 8.6.
Krivan
(2,301 Views)
