stationary grid in waveform chart
Hi
I want to plot a moving waveform chart and the background grid should be stationary. I had ploted graph as well as grid. but while the graph moves the grid also moves. could any one suggest me how to make a stationary grid as background in moving waveform.
Thanks in advance
(3,567 Views)
Accepted by topic author somnath
A waveform chart is showing the historic value of a waveform over time, so the relevant grid marks have to move with the waveform data to have any relevance, think of it like an old paper chart recorder. If what you are trying to do is more like an oscilloscope then the correct display would be a waveform graph.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,561 Views)
Thanks alot LV_Pro
You understood exactly that I want to do something like oscilloscope. So I also want to control the distance between gridlines in background. If you could, a simple example or little guidence would be more helpful for waveforme graph, because I dint find any option in waveform graph for my purpose.
Thanks in advance
(3,548 Views)
