status
I would like to know what is the status is used for, if you have any example of what status could be use to.
(2,964 Views)
Olivier,
i somehow miss some important info in your question: WHAT status do you mean?
Norbert B.
Norbert
Expert: Geometry
(2,956 Views)
Norbert tell me if I am right,
I have seen that status in an entry of an event case but i think, after a little research in the program I must analyse that it comes from an error cluster so it might be something the programmer have defined.
But as far as i can see in other examples it is often defined like that.
Thanks for your help.
(2,954 Views)
If you are talking about the Status bit in the Error Cluster, it is simply an indicator showing if an Error has occured. If the bit is True (showing a red 'X') then there was an error somewhere in the chain.
If this is not what you talking about, please provide some more details.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,942 Views)
