steer panels with some buttons?
Hello everybody,
I would like to steer with some buttons the appearance of some sub-panels, where one is above the other.
When I push for example "Button_1" the "panel_for_Button_1" is at top.
When I push for example "Button_2" the "panel_for_Button_2" is at top. ...
How can I steer the panels to get one the uppest? Or is that not possible?
thx for answering
(2,505 Views)
what you could do is use the subpanels in a tab control with the page selector turned off. then you could use some boolean logic and a case structure to show the page with the subpanel you want on top.
this may work correctly But I have never tried it.
Joe.
"NOTHING IS EVER EASY"
(2,498 Views)
