step wave generation
Hi all,
I have a Galvo mirror form Thorlabs, and I want it scan along the x axis, (let’s assume -10°-10°,increment by 1°, pausing 1 sec in between). Because the angle is proportional to the voltage applied to it. Which means the voltage should be also like this:
The question is I really don’t know how to generate this step wave in LABVIEW, please help me with your brilliant idea.
Thanks a lot in advance~
Muchas gracias~
(2,494 Views)
Hi Carlos,
you just change an output voltage at regular time intervals to generate that "step" output signal…
(2,487 Views)
Hi GerdW
 Thank you so much! I think you are right, but i need a lot of small steps, like hundreds. Do I have to change the output voltage one by one?
(2,478 Views)
