stepper motor interface with labview and arduino
Hello everyone
i am having problem with my coding. I have to make the stepper motor rotate accordingly. i am sorting object where specific QR code are stick on it.
However, when the qr code on the object is scanned, the motor should rotate to a certain degree and then go to the home position. and when scan another object, it should rotate as well and then return to the home position.
when i am trying it in my GUI, like with the scanning all that. it is not working properly
But i did try my motor circuit with the lIFA for the example of stepper in the labview which work perfectly. when i give a certain angle, the motor rotate.
Can some1 help me please. i will be really grateful.
My GUI and image processing for the QR code is in labview where i use vision acquisition and Vision assistant to make it work,
Message 1 of 1
(2,832 Views)
