stepper motor
Iam trying to build a VI to control a unipolar stepper motor, and I found instruction on the NI website in the link below
http://zone.ni.com/devzone/cda/epd/p/id/2080
.. and also found a code online but the code is written in labview 5. here is the link for that code....http://etidweb.tamu.edu/projects/labview/stepper/vi.htm
my question is what changes will I need to make to this code so that it can work in the newer version of the labview..
(3,542 Views)
All the code from the old version of labview should be applicable in the new version, except for the DAQ portion of it.  For the DAQ, you should should functions from DAQMX.  It will be better if you try to build the vi first and ask questions when you experience problems.
Kudos and Accepted as Solution are welcome!
(3,536 Views)
Hi again SK,
There also are upconvert threads that will help you convert the code if you have trouble opening the files.
Jesse Dennis
Engineer
INTP
(3,484 Views)
Hello
Iam using a labview, I have this program,,now iam using for loop.... now i have a voltage comming out of the data acquistion which is are 2V..
Iam using a DAQ assitant in the VI... Now what I want to do is I want to set the For Loop iteration based on the voltage comming from teh DATA acquisation..Like set the number of iterations in the for loop based on the voltage comming from the DAQ..
Attached is the VI that would further clarify what I want to do..
(3,466 Views)
(3,465 Views)
