.stl
I imported a .stl format picture-cylinder and now I need my picture in coordinate system. Is it possible to put .stl in a cwplot3d?
Or if there is another way with draw scale or something?
Thank you!
Zwax
(4,610 Views)
Hi again,
I forgot to say that I use Labview 2010. I also attached my problem if someone has any idea...
Thank you!
(4,593 Views)
What exactly are you tring to achieve? What is your final goal?
*.stl it is used to plot 3D picture control. As you see in 3D picture control you can zoom in, out, rotate, light on/off, camera control.
LabVIEW 3D picture control is mostly used to visualize a model.
Unfortunately, you can not put the scale on it.
Ion R.
(4,587 Views)
I just need my picture in a coordinate system, that's my goal. But i don't know how to do it, because all ˝scale˝ methods needs x, y, z vectors or matrixs...
(4,583 Views)
are you talking about a picutre or a CAD model?
(4,581 Views)
CAD model
(4,578 Views)
If there is an option for 3D Picture Control, it should be in property nodes. If you right click on indicator for 3D Picture Control / Create / Property Node you can choose a list of options that you can read, or write for that particular Control.
(4,572 Views)
