stooping a case structure
 Hi everybody..
I want stop the most inner case structure after executing only once but the count is keep on increasing i cannot use STOP...please help
Thanks in advavce
(3,569 Views)
The case structure is kept inside the for loop and that will get executed depending on the value you enter in the N Value of both the for loops. You can maintain a shift register to restrict the case for single execution.
(3,556 Views)
Sorry Sir but can explain in detail....
Thanking you...
(3,554 Views)
I have attached the vi containing a shift register just check how it is implemented and make it in your logic depending on your preference.
(3,538 Views)
thank you sir...
(3,531 Views)
Hi Everybody
In this VI when Boolean UDA is connected to single case structure is working fine but when it is connected to a another case structure it is showing abnormal result.
I am attaching both the VI. Any suggestion will be helpful
(3,523 Views)
