stop a que running in a sub vi
How do you stop a que running in a sub vi? Please an example would be great.
I have a Que and it runs as a sub vi. The only problem is stopping it do I can do something else.
I have been told you need a refnum but I am unclear on how to make this actually work.
Please help.
Examples of how to do this would be great.
(3,613 Views)
Please provide your code so we can look at it. Depending on your code and how you're handling the queue will determine how you can stop it.
CLD | CTD
(3,609 Views)
I cant post the code company propriitary.
i am just looking for a way to stop a queue from outside a sub vi.
(3,593 Views)
Could you close it in the other part of the code where you use it and then just handle the error in the subVI?
Rares C.
(3,583 Views)
If I am understanding properly, what you actually mean is how to stop a loop that is using a queue.  What I like to do is send a "stop" command of some sort through the queue.  The code in the subVI recieves the command via the Dequeue and stops appropriately.
It would be helpful if you could strip down your code so that we can at least see your framework.  Then we could give better advice.
(3,575 Views)
Here is how to kill your queue within a Producer/Consumer loop Sub VI.
Note: The Sub VI must be re-entrant
If it's a state machine queue then just enqueue an End function and within that case, exit the State Machine and then kill the queue. The point is, you need your "Dequeue Element" to read the "End" function, regardless of your architecture, and then handle it properly.
CLD | CTD
(3,555 Views)
