stop an acquisition task
Hi
I developed a labview program to acquire 4 parameters, I want to stop the acquisition if I detect a voltage lower than 5V on the first channel, is this possible?
another question I am acquiring on NI USB 6212, can I put an analog trigger on one of the inputs, I want them to start the acquisition if I detect a voltage greater than 5V?
thanks in advance
(786 Views)
Put an OR logic on the stop with the conditions given.
So stop or detect a voltage lower than 5V on the first channel
(765 Views)
Unfortunately, USB-6212 does not support analog trigger. See USB-6212 Specifications
Your only option is to read and process the data using program.
https://tmesystems.net/
(748 Views)
