stop runnig when you switch from labview to another application
I've developped a Labview application that need to always be on running continuously for more efficiency.
I wonder if it's possible to make the running stop when you switch from labview to another application, without stoping it manually.
Thanks for your help.
Adnane
(2,471 Views)
Hi Adnane,
you can read the "Is Frontmost" property of the vi and react on it.
Hope it helps.
Mike
(2,469 Views)
