stop tcp listen and tcp read
Hi all,
if i use the tcp listen and tcp read blocks with a time out of -1, how can i stop their execution if they are waiting for incoming connection or data?
The tcp read block is in a while loop and the stop button state isn't evaluated, since the read block is in wait.
some one can tell me a solution to this problem compatible with S-RIO target device?
thanks
(5,201 Views)
Hi giac82,
create your own connection to this port. You can then stop your program, because the listener isn't waiting anymore.
Mike
Message Edited by MikeS81 on 07-07-2009 06:09 PM
(5,200 Views)
i try to explain better with an example.
1) run the server
2) run the client
3) try to stop the server without stopping the client --> the server never stops due to the infinite timeout on the reader.
note: the client doesn't  close the connection after sending "hallo" 4 times.
the question is: is it possible to have the server waiting for data and the stop but evaluated when pushed?
(5,184 Views)
Accepted by topic author giac82
Hi giac82,
i know that you only want to close the server. You can create your own connection to the listener. You need another loop for it.
See the attached picture. It's only a small example. You can make it more complex to react on different statuses.
Mike
(5,182 Views)
