stop watch
Im trying built a stop watch for my program. I want to built a stop watch with start, stop(pause) and reset button, but dont affect main program, i want to display watch as seconds, minutes, hours and days(all are in seperate numeric indicator, im using LabVIEW 2013...please help me...
Message 1 of 16
(8,178 Views)
Hi mak,
I'm trying built a stop watch for my program.
What have you tried so far?
That request comes up very often. Sounds like homework to me…
Use a parallel loop…
When you need seperate indicators some additional math is involved. But it's just some very basic math and easy to program…
please help me...
Show what you have done so far. Ask for specific problems and we will answer your questions.
No one will do your homework for you!
Message 2 of 16
(8,172 Views)
Thank you for your reply...i done some work...like using elapsed time, i use elepsed time(s) as input for a sub vi (which convert seconds to days- hours - minute- second formate)
Message 3 of 16
(8,157 Views)
But how can i use start button....after running main program i want to manage (stop/start/reset) stop watch
Message 4 of 16
(8,151 Views)
I would never ask a mechanic to fix my car without bringing my car to him.  Please post some code so we can help.
Message 5 of 16
(8,138 Views)
I know I shouldn't but here is an idea of what you could do. It only handles seconds though. You'll have to try to convert them in hours and days on your own, and as long as you try the community will help I'm sure.
Message 6 of 16
(8,120 Views)
I think it is fine providing solutions to a user.  Some times seeing how others do it helps understand different ways of doing it.  But you mentioned needing to do math to display minutes and hours, but all you need to do is change the display format of the indicator.  Attached is an updated version.
Message 7 of 16
(8,111 Views)
Nice. In my haste I didn't think of that.
Message 8 of 16
(8,101 Views)
Thank you for your help, i done some work but i had still problem, when press stop button it stop(pause) in display, but runs in background, Example: Current time 34s and i pressed 'stop' button it shows '34' After 10 second i pressed 'start' button again, then it Start from 44 s instead of 34 s Please help me Here i attach my program
Message 9 of 16
(8,054 Views)
Here my program
Message 10 of 16
(8,048 Views)
