stopping a while-loop in a sub-vi
I want to stop a while loop that runs in a sub-vi. It does not work with a local variable, is there a possibility to implement this without using global variables?
Many thanks !
(3,112 Views)
One way is to use a notifier.
See attached - Uses LV 7.1.
Message Edited by NeilR on 05-04-2005 08:10 AM
(3,093 Views)
There are many different ways of doing this. you could use notifiers or ques or just simply pass a reference to a stop button and use a property node to control a loop. I would suggest looking at the many examples that ship with labview for a demostration of each.
Joe.
"NOTHING IS EVER EASY"
(3,081 Views)
Great !
Thank you very much !
(3,079 Views)
