stopping an event sequence
So I am running about 10 different machines, about half at a givie time. Everything seems to be working great but one of the processes i would like to be able stop. I am using an event sequence to trigger different processes, i would like to be able to stop one of my events if lets say a certain condition is not met. But once the event starts and runs its stacked sequence I can not stop it. Is there anyway around this?
Message 1 of 28
(6,333 Views)
Generally speaking you have two options.
Code all of the frames in the Timed Sequence to check for a flag to control execution
OR
Re-code it as a state machine inside a Timed loop and struture the state machine to check for the work/no-work flag.
Ben
Message 2 of 28
(6,325 Views)
Now I am not using a Timed Loop or Time Sequence since the process i am running can take either and hour or four, so will this work an a stacked sequence
Message 3 of 28
(6,318 Views)
This is exactly why stacked sequences or even flat sequences is frowned upon.  You cannot stop it in the middle in case of errors or some other event.  Ben has given the best advice, convert to a state machine.  You can put error or event checking in each state to dictate what the next state will be.  Sort of like this:
If error
  NextState=exit
else
  NextState=NormalNextState
- tbob
Inventor of the WORM Global
Message 4 of 28
(6,311 Views)
Yikes!
The same suggestion for the timed seq will apply to the stacked seq but the only difference between a stacked an un-stacked sequnce (aside from experienced LV developers knowing better than to use a stacked squence, Yeeesh!) is the flat version is easier to read.
Ben
Message 5 of 28
(6,303 Views)
This maybe a stupid question but how do you create a state machine
Message 6 of 28
(6,293 Views)
I would get away from the Stacked Sequence Structure.  It gets nasty when using them.
As the name suggests, it's a sequence, which means that unless you use case statements around your code, you won't be able to control your code based on changes in events.  As a matter of fact, unless done properly, you may not be able to control the code within a stacked sequence even if you do use case statements. I won't get into details.
Message 7 of 28
(6,292 Views)
Glad you asked..  That is the right question..  😉
The easiest answer is to do a search on the topic.  I think I have a tag where it is well described (I'll look for it).
Message 8 of 28
(6,289 Views)
Attached is a simple state machine example.  It can be used as a start.
- tbob
Message 9 of 28
(6,282 Views)
Message 10 of 28
(6,279 Views)
