storage and analysis
It is a student fromTurkey,
I ve a question about storing some measurement data which are already imported (DAQ). I need to make several measurements of the same kind again and again  in one session, and store them in my computer and i also want to see each of them in my labview panel one by one as i finish one and pass to another measurement. i mean, when i finish one daq, i want that measurement file to appear on my panel and wait to be analysed untill i finish my measurements. when i finish daq, then i want to start my calculations one by one again. i have tried plenty of ways but still havent achieved.  i hope you have some advices about it.
Regards ,
Emin Eksi
(3,290 Views)
There are a lot of ways to store data at your computer. See the "File I/O" pallete.
There are a lot of ways to display data too. Graph, Chart, text....
Depending of your needs.
For your program i suggest a state machine, although i don't know what exactly you want to do.
(3,280 Views)
Hello Emin,
I suggest you open the Fundamentals>>File Input and Output and Fundamentals>>Graphs and Charts sections of the NI Example Finder (Help>>Find Examples).  These examples will give you a broad overview of your options in LabVIEW.
As a student, you may also be interested in the Express VIs.  In particular, I suggest you look at the Write To Measurement File Express VI (found on the Block Diagram Functions Palette under Express>>Output).
Best Regards,
T. McCarty
(3,244 Views)
