storage solutions using TDM
the TDM format looks very promising. However I couldnt yet find in-depth information at the NI website for best practices and solutions. For example, what is the best way to store 2D data (x- and y-array)? In particular if I need to store several 2D data sets in one file. Store the arrays of each 2D set together in a group? Is it possible to build sub-groups like this:
[tdm-root]
[measurement1]
[xy1]
waveform1
waveform2
[/xy1]
[xy2]
waveform1
waveform2
[/xy2]
[/measurement1]
[measurement2]
[xy1]
[/measurement2]
[/tdm-root]
Is there a way to store arbitrary scalar values in the properties of a group? With respect to the above structure, store sensor data and othter info that applies to all waveforms in the group in the properties of [measurement1],[measurement2]? The wizzard vi's seems to allow only 3 str values...
I would appreciate any hints and tips on this topic. Maybe I missed some important part of the documentation?
thanks
klaus
(2,813 Views)
Hello Klaus,
sorry but, but your example doesn’t work. It’s only possible to have 3 hierarchies in the TDM-format. These are the Root, Group, and Channel hierarchies.
You should use for every array a separate group, but you can implement 2 channels in one group.
I’ve some interesting links for you:
NI TDM Data Format
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
(2,764 Views)
