10-10-2007 11:05 PM
10-11-2007 01:14 AM
10-12-2007 11:48 AM
Actually,
If you are running on a small form factor machine running Windows, you won't need to install LabVIEW on each machine (that would be costly) but can create an executable (it will require you to have the Professional Development version of LabVIEW or buy, if it is still sold seperately, the "Application builder") and only have the executable and the LabVIEW runtime engine installed on your deliverables. As to using National Instruments hardware, it will probably lower your NRE (non-recoverable engineering) costs by making the integration of the hardware with the software easier. Not such a big deal where the resulting software and hardware are going to be replicated an number of times, then the actual cost of the hardware comes into play, but in many of my projects, where we may make only one of an item, it can actually save a substantial amount of money to have the hardware "play nicely" with LabVIEW, which National Instruments products generally do.
10-12-2007 12:04 PM
