store data in array just when there is data.
@amkamyab wrote:
i want to record time of each data in array that i can see delay between pushing buttons.
Maybe the attached example can give you some ideas. The possibilities are endless!
Message 11 of 15
(989 Views)
Thanks again for your help. it is very useful.
what i want to see is duration time between two true value in array as i showed in picture. my program attached also here.
Thanks again
Message 12 of 15
(978 Views)
My earlier code should have enough hints for you to do that, but your case is even simpler, because the time increment are multiples of the loop time.
Maybe all you need is an output array that contains the durations. The booleans are all the same, so that's not worth storing.
(btw, it is difficult to program if the front panel is maximized to the screen. Why do you do that??? Is there a reason you are using "built array" and "insert into array" to do the same thing? Why are your feedback nodes initialized differently?)
Message 13 of 15
(970 Views)
may i ask you give me your email that i send real program that i have, that you can see what is it exactly?
Message 14 of 15
(963 Views)
(No, that's not how the forum works and you could not afford me as a private consultant. 🐵
Simplify your code to a minimal example that still shows the problem, attach it here, and give everyone a chance to help.
Message 15 of 15
(952 Views)
