store scanned output in the excel
Hello everyone
i am trying to store data in the excel.
I am saving it in terms of 97-2003 workbook
But when i put the link of the location in the labview so that i can
data can be stored to the appropriate place.
But it is not working. i even put.xls when saving.
still i am having an issue.
when i open the excel individually. nothing is stored
Can somebody please help
i did attach one part of the coding
Message 1 of 12
(3,850 Views)
Hi Zahkay,
with all those wire bents your data gets stuck in those wires! 😄
Ever tried the AutoCleanup tool? It usually makes block diagrams nicer…
For your specific problem:
- How can we help when we don't have your VI?
- Did you check your VI with debugging techniques like probes?
- Did you receive any errors while saving data?
Message 2 of 12
(3,834 Views)
Your code has nothing to do with excel. You are creating a text file.
What is the purpose of the feedback node?
Message 3 of 12
(3,819 Views)
Hello
 I did the auto clean up.
But still i am having the same problem.
i did upload my VI
Message 4 of 12
(3,795 Views)
Hello
i did upload my VI
Message 5 of 12
(3,795 Views)
Hello
I did put the link of the excel in terms of xls.i am not able to use any notepad
The feedback node is used so that the data is not repeated.
This is only one part of my code
Actually, before i was able to save the excel in term of 97-2003 workbook.but now when i am creating new
it is not working
Message 6 of 12
(3,788 Views)
Gerd was only joking.  The bent wires just slows the data down - it doesn't get stuck.
Seriously, though - if you actually did think that cleaning up the block diagram would solve your problem, it's HIGHLY recommended that you re-assess your prowess with LabVIEW and start over from the very beginning.  This tutorial is a start, but I think you should really read a few books on it, too.
Bill
CLD
(Mid-Level minion.)
Message 7 of 12
(3,761 Views)
Dear billko
i know its a joke. the aim i did the clean up is to represent my work before posting sir.
This was my aim and i remove some part of my GUI which is not needed right now. I am
here only to solve my problem which is the excel which is not storing the data. I did went through
the tutorials online. I am not successful that is why i am here to ask questions.
Thanks you for ur solution. will look deeper into it
Message 8 of 12
(3,742 Views)
Forget about excel for the time being. You are writing a text file so just use txt as an extension. Then probe the input to the Write to Spreadsheet. Check the data into it.
Message 9 of 12
(3,738 Views)
I didn't get you. what do you mean as text file
Thank you for helping
Message 10 of 12
(3,730 Views)
