storing internal variables in mathscript/scilab nodes
Is it possible to store values of internal variables in mathscript nodes? Maybe having an initialization section where variables are set up, and then updated afterwards. And then something to reset them when the vi closes? Im guessing not, im guessing that we have to do the same thing that labview does, pass the new outputs to the inputs, but it is much more natural in a text based language to do it this way (for me anyways).
(3,058 Views)
Accepted by topic author Gordal
Hi Gordal,
You can use the save and load commands to store variables for your scripts into a file.  Note that these commands will cause a warning glyph to occur which reduces performance, so what I suggest is the following:
(3,037 Views)
