storing visa resource name in teststand variable
hi,
can i store a VISA resource name into a teststand variable using set property api of labview ?
if yes then may i know how ?
regards
-giri
(3,182 Views)
Accepted by topic author giri2309
HI Giri,
You may store it as a String Variable in the TestStand using the "Set Property Value - String".
Nitz
(Give kudos to Good Answers, Mark it as a Solution If your problem is Solved;))
(3,179 Views)
when i load a vi wit visa resource as input in teststand, its taking resource name as container with a string and a number as its components , if i consider it as string as u said i wont be able to map those two.
(3,174 Views)
