storing waveform samples
Hello fellow engineers,
I have an interesting programming problem and I would be delighted if all of you could help me.  I have a CRio controller that returns signal waveforms of various paramters. I have to
1. collect W samples of each waveform.
2. I have to collect these W samples once every Y minutes. (assume sampling rate of 1000 samples /second)
3. Calculate the average of the W samples for each waveform.
4. Store the calculated averages as a tdms file.
I have been able to collect W samples for each waveform, find the averange and store it. But, I am not able to find a way of doing this once every Y minutes. When I use a timed loop or any structure for that matter, the extraction of the waveforms over W samples doesn't seem to work.
I await useful insights and valuable suggestions,
Thanking you all,
Aparna.
Student,
Germany.
(2,907 Views)
Hello, I have attached a very simple example for measuring time in LV. Maybe this can give you an idea. Regards Ruediger
(2,864 Views)
