str to ip function returning '0' for port 2 (eth1) on cRIO 9068
I am using a Win7/LV2K15 (the "laptop") to develop a project on a cRIO-9068. I went into MAX and configured the 2 ethernet ports as follows:
eth0: 169.254.0.1 / 255.255.255.0, static configuration -- ethernet connection to laptop.
eth1: 192.168.9.1 / 255.255.240.0, static configuration -- no ethernet cable attached
Is there a reason why the str to ip function within labview is returning a '0' from index 1 of the multiple output mode's array output?
(2,106 Views)
What happens if you connect a cable?
(2,085 Views)
