strain gauge connection to WSN node 3214
Hello Friends,
 I have brought cRIO 9075 and wsn gateway 9795 and wsn node 3214.
what i need to do is to measure the force using strain gauge. I have connected strain gauge to wsn node on my own way. But I am not getting any signal from the strain gauge
here by attached the picture, how i connected the starin gauge.
Is this the right connection or do i need to change something else. Kindly help me , i am in the state of confusion.
strain gauge specifications ( 120 ohm, n type). Connected strain gauge terminal to AI0 pin on wsn node
Thanks in advance.
(3,616 Views)
It's impossible to say how you've connected things from those images. You need to follow the instructions for wiring quarter, half, full bridge in the manual - http://digital.ni.com/manuals.nsf/websearch/20BA65A84973636686257A6B0000D0A8.
(3,577 Views)
Hello Denis,
Thanks for your reply.. but i couldnt access this link. Is there anything to do with this.
i have connected one terminal of strain gauge into AI0+ and other to AI0-.
Thanks in advance
(3,564 Views)
There's just an extra period in the link. The manual should have been the first thing you looked at. It comes with the device. There is not any configuration of strain gauges where you only connect two terminals of the device.
(3,550 Views)
(3,518 Views)
